Battery percentage stuck when charging
On the Swiftpoint Z3 (3.1.2.0 firmware) the battery percentage gets stuck around 32% when charging, this is shown on the OLED display and in the Swiftpoint X1 control panel. Turning the mouse off/on updates it and it shows the correct battery percentage.
I have not noticed any issues with the percentage indicator when the battery is being depleted.
