This is honestly one of the most bizarre crashes I've ever seen.
Control panel when auto started after booting launches fine and works, but if at any point after control panel is closed (whether from a crash or closing normally) it will crash when launching. It only gets as far as showing the icon in the icon tray for a second.
Things that don't fix the issue
- Reinstalling
- Deleting config folder (though this shows a window that it loaded the backup, where clicking ok crashes)
- Deleting the backup folder
- Unplugging and replugging the mouse
So far the only fix is to restart. According to all the crash dumps i've checked (some attached), its some kind of assert triggering from a stack buffer overrun.
