So, I bought the mouse Z2, and I wanna play Batman Arkham knight with it, specifically driving the batmobile using the gyroscopes. I customized the left lean to be the "A" , right lean to be the "S", front lean to be "W " , back lean to be "S", But still feel its not meant to be used like that, I can't get any sensibility in terms of leaning, no matter how little I lean is as if i'm pressing the button, I thought I would be able to control the acceleration by only tilting a little, but it is not generating the result I expected. Is this the right config ? Am I doing this right ?
