I've recently noticed an issue with my Swiftpoint Z's right trigger switch where it will occasionally repeat the output assigned to the button.
For my case, I've assigned Ctrl + W, so close tab for web browsers, but maybe every 3-4 times I pull it, it would close two tabs quickly instead of the one. There doesn't appear to be any correlation with strength of pulling it or how long I hold the switch.
I have attached a screenshot of how I programmed the button in the X1 Control Panel
Thanks in advance if anyone has some thoughts on how I could fix this. I had a previous issue with the scroll wheel click not registering occasionally and that was fixed by cleaning the switch and taping it, but I'm not sure how to access the trigger switches.
