For example:
Tilt Right 1.2 between 2.4 degrees > OLED Scroll Wheel Push > VOLUME UP
Scroll Wheel Pull > VOLUME DOWN
Tilt Right 1.2 between 2.4 degrees Return > Previous OLED
So slightly tilting the mouse the volume can be adjusted but this does not interfere with the Global Defaults (Tilt Right 25 degrees to enter Config).
