As simple as:
When press: Click.
When released: Nothing.
Then: End.
Solved:
The expert mode UI not quite intuitive, but realized there was a setting menu for both press and release.
_
Second question:
Can I reduce the amount of time the tap is being holded?
It is in average 35 milliseconds in hold status.
Can I reduce it to for example 10 milliseconds?
By hand-click it is totally possible to do, yet maybe the mouse macro has a limitation for tap speed.
