Z3 More battery percentage display options in X1 Control Panel
It'd be nice to add options to show the battery percentage in more places.
  1. Option to show simple text when hovering over the X1 icon in the system tray. Could be a convenient time to display other device info, like device name and Profile.
    1. Related option to replace the X1 icon with a battery percentage.
  2. Option to show battery percentage in Config Mode.
    1. When tilting the mouse to enter config mode, the time it statically says 'Config Mode' would be a very convenient time to also see the battery level. I'd think this is the most elegant solution, because it's when I'm already tilting the mouse to look at the OLED screen; it's something I could easily access from any other profile without changing other profiles' OLED options (looking at you, spinning cube).
  3. Option to show battery percentage all the time on all OLED options.
